SXR-800 possible Oil Water Mix in combustion chamber ????
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Dec 2010
    i dont know yet
    hi folks,
    took the head of for just an inspection, ski ran fine rpms good no bogging nothing...
    looks like there comes Water in the combustion chamber ?
    i dont know for sure... i did install an new head gasket but it didnt change... what do you think cause this ?
    Oct 2013
    Ohio
    Re: SXR-800 possible Oil Water Mix in combustion chamber ????
    I realize you are looking for answers, but I have only questions.
    I am curious what caused you to think and engine that is running fine need an inspection, what were you expecting to find?
    A better set of photos would be helpful. You show one piston along with two chambers. Is the wet looking shine oily or just wet?
    In photo #1 there appears to be a ding in the chamber at about 2:00. Is there a matching ding in the piston?
    Are photos 1 and 2 from the same cylinder? What does the piston matching photo 3 look like?
    Riverside, CA
    6
    Seized.
    Was the head gasket blown?
    If I was to guess, when you were riding and the engine shut off
    like it ran out of gas or something. Then it restarted and seemed
    to run fine.
    That dark colored piston crown is the result of detonation.
    You need to determine the cause of the detonation, or the rebuilt
    engine will seize again.
    Bill M.
    Apr 2005
    Texas
    Look at the pisser stream to see if you have a leak. If its steady there is no leak. A small leak will let out a lot of combustion gas but very little water can flow back into the cylinder. Now you need to clean all the black sealant off the head and cylinder and use a new gasket. Make sure there are no dings in the surfaces because it will create high/low spot that the metal gasket may not seal.
    Dec 2010
    i dont know yet
    Engine is NOT SEIZED.
    RUN perfekt 6800 rpm all day long.
    I just took the Head of to take alook nothing else. Ski ran finde. Pisser stream is steady.
    Dec 2010
    i dont know yet
    Its just want to take a look how everything looks, northing else. no dings ist is a mix of Water/Oil... it look like this...
    Dec 2010
    i dont know yet
    Well when i shut off the Engine then some combustion gas/Smoke comes out of that Pisser... So i will bring the Cylinder and the Cylinder Head to an Shop to mill and then i will Install an new head Gasket.... best way or ?
    Apr 2005
    Texas
    Quote Originally Posted by Felix #86 View Post
    All skis port cooling water into the exhaust system. Pisser ports are attached to the top of the cooling system so they bleed gasses out of the system. Your engine was fine. Now its important to carefully clean the surfaces and put it back together. Do not use any power tools!
    Sep 2012
    Huntsville, AL
    That's normal.
    Dec 2010
    i dont know yet
    ok but why is oil/water mix in the engine ? just bad head Gasket ? The Pictures are one year old at that time it was a paper head gasket since then i got an metal head gasket... i didnt open the engine since then..but ran fine all year... so i guess i need nothing more to do...
