95 xp motor swap question
    Resident Guru DamageInc's Avatar
    Apr 2014
    Pismo
    I've got a really clean 95 xp hull with pump, but no motor or waterbox. I also have a clean 96 787 xp motor looking for a home.
    Questions are:
    Can I put the 787 in this hull, and if so, since the 95 hull has the 4 motor mounts vs 3 in the 96, is there an adapter plate available thru anyone, or should I glass in a new one (or set of 3)...?
    Not sure what motor came stock in this ski...
    So is it worth it to drop the 787 in there? I don't mind the labor or modifying, as long as it'll be a fun ski for my girl.
    96 xp stocker w/ the works
    96 xp stocker
    96 xp project
    92 X2 650/750 conv build
    90 JS440/650sx conversion
    04 YfZ450
    05 GSXR 1000
    PWCToday Newbie offroadtoys's Avatar
    Jul 2012
    Oak Harbor, OH
    Re: 95 xp motor swap question
    95 XP came with a 720. Good motor and can be made to rip pretty reliably. Had 85hp stock in XP twin carb form. Can't comment on the conversion to 787 but it would definitely fit with mounts.
    Riverside, CA
    6
    Maybe you can find an HX 785 conversion thread?
    Bill M.
    Apr 2014
    Pismo
    Yep, found a few threads. Thanks.
    Not worth the hassle after all.
    96 xp stocker
    96 xp project
    04 YfZ450
    05 GSXR 1000
    Riverside, CA
    6
    Quote Originally Posted by offroadtoys View Post
    Both engines basically have race porting near 200 degrees of
    exhaust duration. The 720 can make good power despite the
    short stroke.
    Bill M.
