1995 Sea doo XP - Starts but quickly dies - New MPEM
Results 1 to 10 of 10
    Oct 2021
    Marlborough, MA
    Hello everyone.
    I have a 1995 Sea Doo XP that I have replaced the MPEM in. It starts buy quickly dies. Please help. I have been told that it needs a new Stator.
    Riverside, CA
    6
    Re: 1995 Sea doo XP - Starts but quickly dies - New MPEM
    There were 2 Xp's released in 1995. The 1995 Xp was a 720, and
    the 1995 1/2 was the Xp800?
    Bill M.
    Oct 2021
    Marlborough, MA
    It is a 720 XP
    Post falls Idaho
    4 wire stators are tough , Iíll sell ya a good one , hardly ever fail unless rusted , Chinese MPEM ? Check your e box ground with a jumper lead before buying too many parts
    Riverside, CA
    6
    Does it have weak spark?
    Bill M.
    Attached Files Attached Files
    With spark plugs out can you rotate the engine a full 360* by hand using the PTO?
    Post falls Idaho
    Yep could have a stripped rotar shaft gear , myself
    Oct 2021
    Marlborough, MA
    I replaced the MPEM and start/stop button.... still starts and dies. I unplugged the red black wire near MPEP and starts and stays running. Please advise
    Is that the black with red stripe? If so then you need to check the operation of the lanyard switch.
    Oct 2021
    Marlborough, MA
    yes, the black and red stripe. I will check lanyard switch. thank you
