Yet another square nose build
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
    I dream skis MTRHEAD's Avatar
    Nov 2003
    MotorCity
    Picked up this square a month ago. Planned on painting it but paint turned out to be in solid shape after cleaning. Ski has sat for many many years. Planning for vintage race (buoy riding) legal build.
    Nov 2003
    MotorCity
    Re: Yet another square nose build
    92ABF581-1BDF-4C48-83E8-E14A0CECD4ED.jpeg2C55D4B0-1546-49AB-9A08-C9007747117B.jpegD15FF662-454D-481E-A890-F2F95F642B89.jpegConverting to round nose pole. Scored unused 2020 for $150 and scored the hazard bracket
    Nov 2003
    MotorCity
    Emptied the Hull. Out with 61x, old internals, and garbage mats
    Nov 2003
    MotorCity
    Go fast and handling tricks. Pump stuffer, true bottom and 2 setback
    Nov 2003
    MotorCity
    2” (50mm) setback will use 08+ driveshaft so no custom made shaft required. Skat setback pumps are actually 30mm. Prop edge against the driveshaft. So this is 20mm more which shouldn’t hurt. Same as sport spec guys run and I have in my blaster sport spec boat
    Dec 2005
    Wisconsin
    5
    Did I sell you that stuffer ?
    WHEN IN DOUBT, GAS IT!
    Nov 2003
    MotorCity
    Yes I think. I’m going to mod it some to reflect what we did back in 00-02 with stuffers.
    Top Dog JC-SuperJet's Avatar
    Cypress, TX
    Nice Vintage Build MotorHead.
    Can you also list the approximate Parts Costs along the way, especially the Pump Setback Mod Kit, etc...
    Subscribed! How many more of us are currently building squares??!!!
