Just another silly Squarenose re-do - Page 3
Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 104
    Dec 2005
    Wisconsin
    5
    Re: Just another silly Squarenose re-do
    A washer in the exit tube of a FP waterbox??
    I've never seen any aftermarket waterbox with any kind of restrictor in the exit.
    WHEN IN DOUBT, GAS IT!
    Resident Guru MTRHEAD's Avatar
    Nov 2003
    MotorCity
    This is picture of the factory pipes wave blaster racing waterbox. Welded washer for back pressure.
    Dec 2005
    Wisconsin
    5
    Quote Originally Posted by MTRHEAD View Post
    Ah, gotcha, and yeah I have seen that in the blaster box, just never in any SJ box.
    Dec 2005
    Wisconsin
    5
    Dec 2005
    Wisconsin
    5
    The bilge pickup is an easy fix when everything is out of the way.
    Pulling the midshaft next for inspection and spline lube
    Dec 2005
    Wisconsin
    5
    Well, the midshaft spins buttery smooth, but the pump bearings, umm, not so much.
    And of course 1 of the 4 pump thru bolts is missing and the other 3 were finger tight, you know, cuz loctite is hard to use N stuff, lol.
    Time for some press time and pump work. And the skat 14/20 impeller is interesting...can't say I've even heard of that pitch. I've had the 13/18, 14/19, and 15/20...but never a 14/20. And the splines are begging for a healthy layer of anti-seize, as they were bone dry.
    Like I said, I didn't need to ride it before taking it all apart first. Same sh1t, different decade.
    Good thing is I have everything in stock and in my stash to get all of this sorted out nicely.
    20211010_203610.jpg20211010_203618.jpg20211010_203626.jpg20211010_203629.jpg20211010_205141.jpg20211010_205143.jpg20211010_205156.jpg
    Aug 2010
    delavan, wi
    This machine reminds me a lot of when I got my 90 SN. I had a bunch of stuff to sort through too. I had a missing pump bolt too.
    I'm curious about the porting, do these Yamaha exhaust ports come smooth from the factory? Mine were really smooth, i was ready to do some polishing when I took it apart and it was pretty smooth. Top end on my SN was the first Yamaha top end I ever did, so I didn't know what exactly to expect. It did have stock pistons, no overbore or anything though.
    All the Kaw and Poos I've taken apart had some pretty rough casting in the exhaust ports. Not sure if the Yams are just smooth or if it means someone's been in there.
    90 Superjet - Coffman pipe, other mods
    98 Polaris Pro 785 - stock graphics, just ported and polished
    98 Polaris Pro 785 - black top, cylinders milled .020, ported, polished, watcon cooling
    95 Kawasaki 750 sxi - R&D pipe, ported, polished, bored 1.5mm over
    01 Polaris 600 sc xp sled - Stock
    Dec 2005
    Wisconsin
    5
    Quote Originally Posted by pro785 View Post
    The give away is when the window in the sleeve is a smooth transition to the exhaust runner. Then you know it was ported/worked on. When stock there will be some sleeve overlap.
  9. #29
    That pump is begging for some grinding. I blueprint all the pumps on my personal skis.
  10. #30
    Dec 2005
    Wisconsin
    5
    Yeah, me too, or I run Solas mags.
    If I was keeping this ski and planning to ride in jet wash (aka, race it) or ride it in Lake Michigan surf a lot, I'd put the time and effort into blueprinting.
    I haven't shared my secret plan for this ski yet, but I doubt it will remain in my hoard after I've finished it.
