650sx best mods for low end
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
    PWCToday Newbie DudeWithAJet's Avatar
    Aug 2021
    New York
    I have an 89 650sx that I just got running good and want to get some nice low end power and acceleration. I already have a intake grate and a high compression head, and I donít know what should be on my list of priorityís.
    Thanks, Lucas
    Re: 650sx best mods for low end
    Mod the stock pipe, instructions on several forums. Add a couple inches to the tail section of the pipe. Get a good aftermarket impeller. I have an old school Mako 16 pitch in mine. Mine also pulls pretty good with the stock 28mm carb. This alone will turn it into a different machine.
    Top Dog
    Apr 2005
    Texas
    Quote Originally Posted by DudeWithAJet View Post
    I have an 89 650sx that I just got running good and want to get some nice low end power and acceleration. I already have a intake grate and a high compression head, and I don’t know what should be on my list of priority’s.
    Thanks, Lucas
    The first thing you should do is take it apart and inspect/overhaul the entire boat. They always need seals and handle pole bushings. Plus you need to verify the crankshaft is not rusted and the pump and carrier bearings are quiet. Once the boat is in good shape the next question is, how big are you? If you are much over 150 then a larger engine is better than modifying a 650. It takes a pipe, porting, and an impeller pitched to near 7000RPM before they pull good and top 45mph. A 750 engine with the stock 650 pipe will have better response and go as fast as a ported 650 with an aftermarket pipe. The 650sx struggles with larger riders a lot more than a Superjet.
    Aug 2015
    Birmingham
    More compression, good impeller, sbn44, fiber reeds, cheater mod w/4-5” length added, h2o inj
    Quote Originally Posted by kweasel View Post
    Not true. I'm 6'8" and 250#. My lightly modded 650sx with stock tiny 28mm carb will GPS about 43mph and gets there pretty quick with me on it. Stock non ported cylinders and red colored non modified head. Will outpull a stock 650 Superjet throughout the RPM range.
    Riverside, CA
    6
    Add a TS650 exhaust manifold to your set-up.
    Bill M.
    Top Dog JC-SuperJet's Avatar
    Cypress, TX
    Bill M.
    Why is it better than the Stock SX Manifold? Is there a difference in Outlet Diameters?
    Yes, it's a bit larger. And, it has a divider to keep the exhaust turbulance inside the manifold at bay.
    Post falls Idaho
    9/17 impellor , 81mm 750/800 reduction nozzel , modified shortened pump thrust cone , or the real short one that can be purchased , but top end will suffer with the real short one
    Riverside, CA
    6
    The TS exhaust manifold has a diverter similar to an aftermarket
    exhaust manifold.
    Bill M.
