87 440 Stator Test Ohm Readings
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    May 2016
    Florida
    Been trying to locate the source of a no spark on my ski. I tested the coil using my volt meter and that seems to be in spec with ohms. The stop switch is working. I disconnected that and same no spark. Also tested continuity on the switch. All good there. My next test is the stator but I have not been able to find the exact readings I should see for my ski.
    I have read on here the Exciter should be 100-180 or 216-324. Which on should it be?
    Pulser should be 14.4-21.6 or 20-30. Which one should it be?
    Post falls Idaho
    Re: 87 440 Stator Test Ohm Readings
    Disconnect stopper relay in e box , black wire with white chaser if stator is good to test it
    May 2016
    Florida
    Thanks Bionic. I will try the stop relay as you suggested also. The specs you posted show for a 550. Is that the same for the 440?
    Post falls Idaho
    Yes same same , GI , all same , now the 1980 and down are different , but will still work with your ebox , different flywheels on FC 440/400 engines
    May 2016
    Florida
    Bionic, did a test with my meter and got .14 on red to black and 0.01 on red to gray. Not what I was hoping to see but just to make sure I am doing this correctly. My meter is on 20k ohms setting. My e-box and battery are not in the ski. Is this correct or does the box and battery need to be hooked up minus the stator wires of course to be able to check them.
    Post falls Idaho
    Sounds like a bad stator , disconnected from box to test stator is correct , no battery necessary
    Top Dog FOG's Avatar
    May 2004
    Mesquite, NV
    Set your meter at 200 (not 20K) and check again.
    I'll quit before I sit~~~
    Post falls Idaho
    Good call fog , 200 is your test for 550/440 stators , long day yesterday , but still got out on the water , taking out my 04 sxr stock Flores ex race boat today , supposed to hit 85 here , idaho , today , gotta ride
    May 2004
    Mesquite, NV
    I've known Rob for many years. Funny how his 'stock' racing skis were always faster than every other stock ski!
    Post falls Idaho
    He and I have exchanged lots of info , still have plans for that junk yard dog 550 that he’s racing , but that’s winter stuff , his 04 that I have is on rails as far as handeling goes , and pretty fast too
