62T wanting to runaway out of water, is this normal?
Results 1 to 10 of 11
    Jun 2007
    Alexandria La.
    So I've only ever had Kawasaki 650's and I'm new to the Yamaha's. Long story short the guy I bought the ski from warned me not to rev it out of the water because it would run away, said it was normal but I question that. The ski is a WDK ROK, stock internal 62T, twin 46mm full spectrum carbs,WDK wet pipe, ADA head (180 psi compression), & aftermarket intake/reeds (forget what brand). I'm thinking the free rev issue is a carb or tuning issue but just wanted to get some input from you with more experience.
    May 2005
    Right here
    Re: 62T wanting to runaway out of water, is this normal?
    It's not normal. It sounds like you have an air leak. If you don't find/correct it eventually you are going to toast your pistons.
    Changes aren't permanent, but change is.
    Jun 2007
    Alexandria La.
    Quote Originally Posted by SxiPro View Post
    Yeah don't wanna do that, thank you. I have access to a smoke machine so I guess I'll smoke it & see whats going on.
    87 650SX small pin swap
    12 WDK ROK 701 62T
    Post falls Idaho
    Blown base gasket , check for boost port gasket protrusion , on carb side , spray engine down while running with brake cleaner or carb spray until it stalls , found your air leak , those also leak from eroded anaerobic case sealer glue , like locktite , sucks air between cases , free runs are exciting if your a Virgin to them , pull choke till it stalls , if it’s case mating area you will see oil on mating surfaces where air leak is , no oil means it’s sealed correctly , as you split cases ,
    Top Dog
    Apr 2005
    Texas
    Did you tune the idle mixture needles???
    Jun 2007
    Alexandria La.
    Thank you for the specifics, I'll look for the oil.
    Quote Originally Posted by kweasel View Post
    No didn't touch the low adjustment, just bought it sunday & haven't done anything yet. I didn't want to damage anything.
    12 WDK ROK 701 62T
    Top Dog
    Apr 2005
    Texas
    Quote Originally Posted by WS6HUMMER View Post
    Tune the idle needles out of the water first, they are the bottom adjusters. Open them until the idle slows down. Look for an air leak only if one carb needs to be opened a lot more than the other.
    Jun 2007
    Alexandria La.
    Thank you, & by that you mean the idle set screw that bumps the throttle wheel? If so I did and it seemed to help but I didn't try to blip the throttle, I'm scared lol. The butterflies are linked if that makes any difference.
    12 WDK ROK 701 62T
    Top Dog
    Apr 2005
    Texas
    The carbs have two mixture adjustment screws each plus one throttle stop. They may be covered depending on year model. Research this and open them up, find help if needed.
    Runaway is NOT normal. You should be able to rev out of the water, especially important to blow the water out of the exhaust.
    Runaway can be caused by an air leak (As said above) or improper tune, jetting, adjustment, etc.
    I am guessing due to this being a freestyle ski, it has reverse jetting and is off, resulting in a lean runaway.
    email watcon@watcon.com
    Please visit our web site
