I have no compression after changing piston
    Sep 2015
    woodbridge
    hello I have a waverunner III year 93 the last time I measured the compression I scored 70 on the front and 125 on the rear so I bought a standard piston in sbt and replaced the front piston, put everything back together with new gaskets and I have no compression on the front 30 and on the back 0 what could have happened?
    Re: I have no compression after changing piston
    Did you hone the cylinder? If you had a problem and you just replaced a piston/rings there might be scoring allowing the loss of compression
    Sent from my iPad using Tapatalk
    1995 FX-1: Pro-Tec chamber~Skat swirl~Pro-Tec plate~Blowsion Destroyers
    1990 Square Nose: Blue ported Jetmaniac 718~#ZERO lightened/drilled flywheel~ADA girdled/32cc~701 B pipe/flow control~Hooker 9-15~AAA pole~Pro-Tec rideplate~Tom21 Tubbies and nose piece
    2014 Super jet waiting on a B pipe and Hooker....
    The change on the rear is what’s interesting to me. I would focus on what you did that could have caused that.
    PWCToday.com Is My Home Away From Home SxiPro's Avatar
    May 2005
    Right here
    Quote Originally Posted by 550headache View Post
    Not THAT amount of loss.
    Changes aren't permanent, but change is.
    Sep 2015
    woodbridge
    [QUOTE=550headache;4584245]Did you hone the cylinder? If you had a problem and you just replaced a piston/rings there might be scoring allowing the loss of compression
    no I didn't, but at least some compression would have, anyway I'm going to disassemble and recheck everything
    Aug 2021
    missouri
    Did you forget to install the rings?
    Resident Guru bored&stroked's Avatar
    Dec 2006
    Mesa AZ
    Put the head gasket back on? Remember to install the reeds?
    You can't just slap parts on without at least honing, but the lack of any compression is the first issue to deal with.
    '96 Suuuperjet: 84mm 61x, ported, B-pipe, Dual 44's, Newmiller head 220psi w/girdle, Skat big hub, footholds, AMG green hell mango matte.
    '95 Raider 701: Fiberglass not SMC, Hydrotrailer hitch, ugly purple and yellow everywhere.
    PWCToday Newbie Chesterswims7's Avatar
    Jun 2020
    Seattle
    0 compression means either usually stuck/scorched rings holding in place or you forgot to put the rings on.
