750sx high and low speed needle won't adjust stock 40mm carb
    Jul 2020
    Raleigh
    I have stock 40mm on a 93. I went to check the hi and low speed settings.
    -High speed needle would turn in, but not stop turning. I could reverse it and pull the needle completely out of carb.
    -Low speed needle turns both ways, will not bottom out or reverse out.
    The needles have a plastic cap that sits on the brass needle - maybe the cap is turning and not the needle?
    Am I missing something?
    Top Dog FOG's Avatar
    May 2004
    Mesquite, NV
    Re: 750sx high and low speed needle won't adjust stock 40mm carb
    Pop the plastic caps off. Personally, I never put them back on...pita's.
    I'll quit before I sit~~~
    Jul 2020
    Raleigh
    I pulled the carb off and was able to pry off the caps. Needles broke free. Thanks for the tip.
    Dec 2014
    SRQ FL
    the caps are good for making those "final adjustments" after you dial the ski in really close but yeah theyre a pain in the ***. the keihins are not easy to adjust while theyre on the ski either
