650sx uneven cylinder burn (single carb)
Results 1 to 10 of 14
    May 2015
    SoCal
    Pretty much rebuilt my ski two whole times replacing everything I can think of. Without going into detail, what is everyoneís first thought when they see these spark plugs? Iím not looking for tuning advise because itís impossible to tell what the engine wants at the moment. Iím looking for the reason why they are different with a single carb.
    The ski runs absolutely terrible. Brand new Ada head 35cc domes put me at 150psi in each cylinder, good coil, new crank seals... I can go on and on with specs but would like first impressions. I can respond to any questions and give more details if anyone would like.
    Apr 2005
    Texas
    Re: 650sx uneven cylinder burn (single carb)
    Quote Originally Posted by 440man View Post
    The wet plug is probably misfiring. Try gapping them at .022" and swap the leads front to back. See if the condition follows the plug wires. Its common for older solid core plug wires to break internally and have difficulty firing a plug.
    May 2015
    SoCal
    It’s definitely misfiring. It starts and idles perfect. But when I ride it and I give it throttle it sounds like it’s running on one cylinder. If I give it about 3/4 throttle it clears up though. I tried swapping leads front to back. The problem stays with the cylinder and does not follow the wire. Also been through a dozen plugs with the same results (all gapped the same). Tried new exhaust manifold (thought there may have been a crack), also put in new reeds.
    May 2015
    SoCal
    I will say that the leak down test I performed did not go as well as I’d hoped. I pumped up the case through the pulse line to 8psi and it dropped to 7psi within a minute. I stopped the test there.
    I understand that this would explain the “lean” color on the front plug. Would this also explain the wet rear plug?
    Many times the pressure test will drop 1-2 psi.......but will then hold steady for the next 15 minutes. I would start by replacing the plug wires into the coil and see what the plugs look like then. It's almost impossible to troubleshoot any lean/rich issue with a misfiring engine.
    Plug wire replacement.--->http://www.pwctoday.com/showthread.php?t=393820
    May 2015
    SoCal
    I think i eliminated any electronic/plug wire problem. I extended the rear wire to the front and connected the front wire to the rear. The fouling did not follow the plug wire.
    If you're sure there are no ignition problems then I would pull the carb and use a dental mirror to inspect the reeds.
    May 2015
    SoCal
    Already pulled the intake once before to inspect reeds. I installed brand new boyesons. I think I’m going to look into the possibility of a twisted crank. This thing vibrates like crazy so maybe that’s a sign.
    PWCToday Newbie DudeWithAJet's Avatar
    Aug 2021
    New York
    Did you ever fix the problem? My ski is having the same problem and I checked everything that you said that you did.
    May 2015
    SoCal
    Not yet… still trying to figure it out. I think I need to check the crank next.
    Also thinking about just buying a new (used) complete engine.
    Tired of throwing money at it at the moment lol
