550 steering
Thread: 550 steering
    PWCToday Newbie Mwmiller30's Avatar
    Oct 2018
    Michigan
    550 steering
    Have everything dialed in on my 550sx for carving bouys except the little bit of play in the steering that drives me nuts. What have guys done to get that little bit of slop out of the steering? Do they have any steering systems for the vintage skis?
    Just looking for more ways to spend money on this 550. Haha
    picture of current set up. I know I can re do it again to tighten it up but as soon as a friend rides it and rips on it I know the little bit of play will come back. Looking for any long term solutions.
    Post falls Idaho
    Re: 550 steering
    Yamaha cable ends , try those , stainless fits the pivot balls tighter ,
    Oct 2006
    under a ton of work
    Re: 550 steering
    have a bearing system for you.brand new .
    Re: 550 steering
    Bearing system on both ends of the cable!
    May 2008
    VA
    Re: 550 steering
    FWIT - cable ends are not the only place slop is introduced. The cable itself can (and do) get worn over time by the cable rubbing inside walls of the housing. When the inside of the cable housing gets worn (in the bend mostly) it creates extra space inside the housing. Then when you turn left the cable has room to pull tight to the inside of the cable housing and when you turn right it pushes the cable to the outside of the housing. This slight difference creates enough wiggle room for the cable to introduce slop into the steering. Only way I know to fix this is by replacing the cable.
    Oct 2018
    Michigan
    Re: 550 steering
    I tightened up the steering and got the Showtime Freestyle steering cable no play ends. No play or slob in it now.
    I’d buy the cable ends again as for $20 it’s a huge improvement but be prepared to cut and grind pieces down. The Showtime cable ends are longer than the stock ones so it takes some “customization” to get it all to fit……. (I also installed the cable end on the nozzle but couldn’t get a good pic of it)
    May 2008
    VA
    Re: 550 steering
    Ha - I just installed them on a 550 a week ago and will confirm that they are indeed too long. I found that running a tap down the new cable ends got them to turn in several more turns before bottoming out on the shaft. But that was not enough and I ended up cutting about a quarter to maybe a half an inch off the top of the steering cable in order to get it adjusted correctly. Glad you were able to get the steering tightened up.
