550 Piston Port Stator - Page 2
Results 11 to 14 of 14
    Post falls Idaho
    Re: 550 Piston Port Stator
    60631DC3-7F8E-4410-B9C8-A6FD9279A914.jpeg6CEF4A4B-99B5-4865-A2E1-68A00BB29BC1.jpeg.
    Strap tool is pointing @ cover to be removed from box to test stator
    PWCToday.com Is My Home Away From Home IceRocket1286's Avatar
    Nov 2003
    Detroit
    Thanks, I had already popped the plugs out of the ebox earlier. I discovered that the black wire pin was not properly seated in the white connector, inside the ebox, therefore it wasnt connecting. Previous owner had taken it apart when fixing ebox issues. I re-seated the pin so the flare stuck out and it seems to be charging now. 12.85-12.97 volts when running as opposed to 11 or less yesterday.
    The green wires for the charging coil are OHM'ing low....1.0 and 0.9. We'll see how it runs for the young man tomorrow when he rides it. I'll pull the motor or stator cover after this weekend and check the condition of the green wires on the charging coil.
    Thanks to all for the info and help.
    May still purchase stator or charging coil after I discuss w the owner.
    Luke Nelson - Lake St Clair
    Dabbling in skis since 1993
    Make Stand Ups Great Again
    Post falls Idaho
    Your charging now , they are a slow building , low voltage charge system , check for drains and your done
    Nov 2003
    Detroit
    Good call, will do
