EME 800 Eric Malone Signature - fresh build, fully kitted RTR - Sarasota FL $9000
Results 1 to 2 of 2
    Dec 2014
    SRQ FL
    IMG_6248.JPG IMG_6250.JPGIMG_6256.JPGIMG_6258.JPG IMG_E6227.JPGIMG_E6239.JPG
    **SKI HAS NEVER SEEN SALT - FRESHWATER ONLY!**
    2007 EME Eric Malone Signature 800
    SXR based bottom, Octane based top
    Carbon/glass hybrid
    EME hulls can accept any engine (Yamaha, Kawasaki, Polaris) and can run either style driveline/pump (Kawi/Yamaha)
    Polaris 800 engine, stock bore and stroke. Compression is 180psi
    Top end is fresh with all OEM parts and the crank has been rebuilt by Competitive Crankshaft.
    I built the engine under the supervision of Wade Chapin here in Sarasota.
    -EME signature MSD total loss with adjustable timing flywheel. Spare brain included but condition unknown, msd bench test is $35 or re-pin and test your luck.
    -Novi 48 carbs, Pro K arrestors, Hot Seat intake manifolds, Vforce3 Carbon reeds. Carbs have been fully treated, rebuilt with OEM kits and look brand new inside.
    -RRP pole, Xscream steering, RRP steering stop, Xscream throttle, Odyssey (EME) trim lever, OEM chinpad. Everything moves like butter.
    -EME/Factory laydown pipe with Jetworks FCV. According to the original dyno sheets the pipe makes 20hp more than a B pipe.
    -Skat-Trak Magnum setback 145 pump with trim (Kawasaki driveline), with Skat Trak prop, Skat Trak toploader intake grate and EME rideplate.
    -EME footholds, Xscream scupper valve
    -1 gallon JAZ Pro dual supply fuel cell
    Turn-key, ready to ride. A modified superjet or SXR feels like a 50cc scooter compared to this thing, it has some truly explosive power.
    Due to this being an aftermarket hull, there is no MSO, Cert of Origin, HIN/VIN, or title. Two Brothers Titling said it can get be given a FL title and registered with a HIN for about $175. I can provide a bill of sale which is needed for the titlework.
    Asking $9000 obo - listed outside of the ski community for $10k. Can ship national or worldwide at buyer's expense. Worldwide shipping will require me to obtain FL paperwork for the ski first before it can be crated.
    Dec 2014
    SRQ FL
    Re: EME 800 Eric Malone Signature - fresh build, fully kitted RTR - Sarasota FL $9000
    sold
