Hydroturf Standup Rails
    Aug 2018
    Texas
    When you hydroturf standup jet ski rails… do you glue the top and outside and then use a straight blade to trim the rest, or do you fold the rest under and try to adhere to the inside of the inner lip?
    PWCToday Newbie WhatUpDude's Avatar
    Nov 2020
    So Cal, USA
    Re: Hydroturf Standup Rails
    Quote Originally Posted by keck View Post
    I bought the side rail rolls from Ebay, but next time I would just buy a sheet as they don't give you much to spare. I used nose brace, rear sponsons and washers (through bolted) to hold it down. It's folded underneath. Used a little adhesive in areas it wanted to bubble. I bolted it all down to fit the trimmed excess. Took a day but came out good. Also used a few ss screws in front and rear to secure it down.
    Aug 2018
    Texas
    Quote Originally Posted by WhatUpDude View Post
    25422703-6455-4393-9862-625FA931EE3C.jpeg.
    . Looks really clean!
    Oct 2006
    under a ton of work
    you can glue and roll it under the rail but heat it up at the sharp bend so it doesn't want to pull away too much.
