Installing new lake temp sensor/speedo assembly
Results 1 to 2 of 2
    Resident Guru RenoJetTech's Avatar
    Apr 2009
    Reno,Nv.
    Doing some other work on '04 GTX limited SC, then got request to install new lake water and speedo assm.
    I'd like to install the new one complete, no splicing. Some on the tube and in other forums show or talk about cutting off the pins
    ( I assume both the old and new pins ) from the leads to make guiding the new lead loom thru the small hole and putty stuff and then splice in the 3 pins and mount in connector. Is that what most have done or anybody enlarge the small hole to get unmolested pins thru ?
    Shout out to Myself for making OPAS tubes install much easier !
    '88 550-ride plate,intake grate,intake manfold,carb
    '96 GTX-1mm overbore,F/a's,intake grate,port timed for mid and top end
    '95 FX 1- usually take this motor to 753cc with exhaust porting and reeds
    Apr 2009
    Reno,Nv.
    Re: Installing new lake temp sensor/speedo assembly
    Somebody has had to do a couple, where you at !
