Sxr 1100 jetting - Page 2
Results 11 to 16 of 16
    PWCToday Regular N3vrSat1sfied's Avatar
    Fort Worth, TX
    Re: Sxr 1100 jetting
    Quote Originally Posted by Mikespo12 View Post
    Iím having some issues with my carbs in my 1100 swap as well. Starts and idles fine, but when I go to give it gas it dies out. If I choke it about half way (give or take) it will rev up almost like normal. Did a leak down test with a crappy harbor fright tool and only lost about 1-2 psi in 5 minutes. That was with a set of freshly rebuilt carbs. Tossed a 2nd set on that have worked for me in the past and I was having the same issue when I put them on this ski. Could it be a gasket issue?
    Are you using the same carb to intake gaskets? Does it rev to the moon out of the water?
    Fort Worth, TX
    Ended up with 130 mains, 78 pilots, accelerator pump hooked up.
    Sep 2012
    Connecticut
    They were new gaskets. But Iíve taken the carbs off a bunch of times since putting them on. And no it doesnít rev out likes itís getting to much air so doubt thatís issue now that you say that
    Riverside, CA
    6
    Did you recently rebuild the carbs with Chinese kits?
    Do they still have the stock springs?
    Bill M.
    Sep 2012
    Connecticut
    Vertex gaskets. And the springs that came with the kits. I ordered good gaskets but whatís what they sent not sure if those are a good brand or not
    Riverside, CA
    6
    When a carburetor doesn't transition from the low circuit to the
    high speed circuit, that can be caused by the wrong spring rate.
    It is an example of what happens when the pop-off is too high. An
    engine (any type that uses a diaphragm carb) will start and idle,
    but not transition to the high speed.
    But I do not know if the diaphragm or the lever height are contributing
    to the problem.
    Bill M.
