Waste spark ignition
    Aug 2020
    Sterling. IL
    Hi all! I haven’t tried this yet but thought I would ask. With a 2 cylinder ski using a waste spark ignition, like a 750 kawi I believe, does it really matter which spark plug wire goes on which cylinder? That is since each plug fires twice per revolution 180 degrees apart. Working on the neighbors ignition problem on a 1998 750 stx. I may have to try it. Thanks…
    Aug 2015
    Birmingham
    Re: Waste spark ignition
    It dosnt if it’s wasted spark
    SE MI
    It doesn't matter, both spark plugs fire on every revolution.
