2005 VX110 Random cylinder misfire and no power
Results 1 to 10 of 11
    May 2008
    Crestwood, Ky
    I bought this ski with 300 hours and no history. It has very rough idle and no power. The filter box is dry with no air filter installed. I checked compression with lowest at 145, high 162. When running the center 2 cylinders were not firing, as verified by cold clean plugs while other 2 were warm and semi-sooty. I swapped all 4 coils and plugs from my other properly running VX and ran again. I cleaned the plugs before I put them in so I could get an idea of firing or not. After about 10 mins of running on trailer, still no power but maybe slightly smoother. I pulled plugs this time to find the front plug clean and cold, with the rest warm and semi-sooty. I then put all 4 cloils/plugs back in good ski, and starts and runs fine.
    I did put the 4 coils/plugs from poorly running ski in to good one, and it ran bad so I know I need new coils and plugs, but this is not entire problem?
    I plan to pull fuel injectors next and check fuel pressure/ spray pattern.
    Any other ideas?
    May 2008
    Crestwood, Ky
    Re: 2005 VX110 Random cylinder misfire and no power
    I checked the injectors and all 4 have a nice spray pattern and no dripping. 51 psi at the rail.
    Any ideas?
    so the connection that plugs into the MAS was a little corroded on mine and some days it ran great some days misfires... if you unplug it it should idle perfect... but cant rev,
    May 2008
    Crestwood, Ky
    I'll give it a try, thanks
    Jan 2006
    Florida
    New Spark Plugs? Seen it hundreds of times.
    May 2008
    Crestwood, Ky
    Yeah I tried new plugs, and known good coils from another VX I have. Same issue.
    I'm wondering if it jumped time?
    Swap the fuel rail from the other ski and report back what it does.
    May 2008
    Crestwood, Ky
    I can do that but may have to wait till spring!
    Lay plugs WITH coils attached up on the head and check spark. The VX wiring harnesses are crap, I've replaced a few. I've also found bad/broken wiring going to various sensors AND to coils.
    May 2008
    Crestwood, Ky
    Got it, thanks!
