STX 1100 DI Problems
    Jun 2021
    Michigan
    Hello, about two months ago I purchased a used 1100 DI. The ski ran great the first time I took it out. Drove about 30 miles straight. I took it out again and the ski won’t get above 6000 rpms and after about 2/3 throttle it seems to loose power. But the ski ran fine besides that so I was just running it and wouldn’t go above 2/3 throttle. Then this past weekend I had it up north and ran it basically all day. The ski ran great but I was getting weird electrical issues. The dash was going crazy and would freeze the speedometer. I made sure the battery connections where fine and kept running the ski. Then the next day I was getting a battery error light on the dash and I would get a check engine warning when the ski was off but it would go away once the ski was running. Later on after running the ski I turned it off and went to turn it back on but the battery was dead. The battery looked old and had some damage to the terminal so I bought a new one and installed it. The battery warning light is gone but the engine warning light is still there as well the Speedometer goes crazy. Anyone have any ideas what my problem could be. I can take videos of the problems if that helps.
    Thanks!
    Mar 2020
    pa.
    Re: STX 1100 DI Problems
    do you have enough water coming out the pisser....overheat?....fry computer?
    PWCToday Regular guy48065's Avatar
    Feb 2020
    Michigan
    The computer isn't water cooled.
    96 & 97 1100Zxi
    Riverside, CA
    6
    Quote Originally Posted by PBS View Post
    The computer is water cooled, and if I recall properly the small water
    hose that feeds the computer can get clogged at the brass fitting on the
    exhaust manifold and front cover (flywheel).
    Quote Originally Posted by ParkerD View Post
    I am curious about this ride. Would you post the date and location?
    I would like to know if the weather was responsible for the low power.
    Bill M.
    Feb 2020
    Michigan
    The computer is water cooled...
    My bad. I looked at several STX1100 diagrams while trying to figure out my own overheat issue and I missed the unique difference to the DI version.
    96 & 97 1100Zxi
    Riverside, CA
    6
    Quote Originally Posted by guy48065 View Post
    Did you fix your STX?
    Bill M.
    Feb 2020
    Michigan
    My overheating Zxi? Yes. The problem was a restriction in a little brass elbow that feeds water from the stator loop down into the expansion chamber where it goes on to fill & cool the water box.
    Everything else (hoses, fittings, gaskets, water jackets) was clean & clear.
    I was exceeding the 120*C max of a little temperature readout I had added. Now the highest it hits is 60*C on the surface of the water box.
    96 & 97 1100Zxi
