1200 Crank Rebuild
Results 1 to 2 of 2
    Top Dog X2guy's Avatar
    Jan 2003
    Barrie, Ontario
    1200 Crank Rebuild
    I have a 2002 Virage TXi crank that needs to be rebuilt. I've done a few seadoo and yamaha cranks myself however I'm not sure exactly how to do this one. It seems as though the 2 center crank pins are pressed into blind holes on the flywheels making them impossible to push out. I could make up some fancy tooling to separate them but it wouldn't be worth it over having someone else do it. Am I correct on this? Has anyone pulled one of these apart that can give me an idea? Thanks
    Dec 2006
    Burnet, TX
    Re: 1200 Crank Rebuild
    I did a couple when I was a mechanic at a Polaris dealer. This is the tool kit we had. The one used to disassemble that part is in the bottom right corner of the picture. You also need a press with a wide enough space between the beams that support the work for the crank to fit.Polaris_Cranksha_53d13afa95cf8_900x.jpg
    Sent from my Armor 9 using Tapatalk
