1989 650SX no water coming out of pisser…
    PWCToday Newbie DirtyD1985's Avatar
    Went through all the lines and elbows and nothing seems to be blocked. I did find this hose undone however, can anyone tell me where it goes?BB8FF820-1CB4-4CEE-9538-AFAB2354E53E.jpeg
    Re: 1989 650SX no water coming out of pisser…
    Well........that would be your main water line from the pump that's supposed to loop back into that open fitting I see in your pic......just above the blue hoses.
    Apr 2005
    Texas
    There are three lines through the hull. The two on the right are for cooling and bilge. The one on the left was a vent for the stock pipe.
    What exactly does the IJSBA do?
    I dream skis needforspeed's Avatar
    Sep 2008
    New Jersey
    Even when you hook your raw water cooling back up so the water is going to the engine, my pisser doesn't piss unless I'm like 1/2 -3/4 - full throttle...I mean it trickles at low rpm...that's about it...just an FYI...
    If it aint broke...don't fix it!!!!
    PWCToday Newbie DudeWithAJet's Avatar
    Aug 2021
    New York
    Did you ever fix it? Mine does the same thing but a little worse. Doesnt come out at all at idle and at anything above an idle really it just trickles out.
