Feels like I have a dead cylinde- spark plug readings confirm?
    Aug 2018
    Allentown, Pa
    Hi guys, I just had my 2007 Seadoo GTI SE out yesterday for the first time of the season. When I first fired it up in the water everything seemed great so I took off and went maybe 1-200 yards. All of a sudden the power dropped instantly. I could still ride and had no problem getting back to the trailer but it was really down on power and idling rough. I'm pretty sure one cylinder isn't firing at all. I pulled the plugs and this is what I found. The middle plug is definitely darker than the others. What do you think? The 2 end ones look lean to me but I'm not an expert. Could a plug have all of a sudden died? Could it be the coil that died? The machine is stock and has less than 100 hours on it. The previous owner which is my Uncle put about 60 of those on it and drove it very gingerly and had it dealer serviced every fall. I'm going to pickup up a new set of plugs ASAP but I really want to ride this coming weekend so it there's a decent chance I lost a coil pack I would probably purchase one of those as well. Is there any way to test a coil with a simple volt meter? After re-installing the plugs, my buddy drove it a little and he said he could smell un-burnt fuel. The plugs are NGK DCPR8E.
    Thanks for any and all help!!
    Re: Feels like I have a dead cylinde- spark plug readings confirm?
    Yes, coil packs can be ohmed out. Primary will be around 1 ohm and secondary IIRC is about 11k ohm. They hardly ever fail. You can also ohm the plugs. Usually when a plug randomly quits, it's because it shorted. Plug connecting tip to the hex/threads should be open. If it reads anything it's bad. Happens a lot. You should install a new set at the beginning of every season.....put a dab of antisieze on the threads and snug them up......DO NOT overtighten them.
    Aug 2018
    Allentown, Pa
    Thanks for the info!
    I’ll definitely get some new plugs but will try to test the old plugs and coil packs before trying to purchase a new coil.
    I hear what you are saying about putting in new plugs every year and if I did I probably would have had more fun last Sunday than I did. But, then I look at modern automobiles and they are running 50-100k on a set. I personally don’t think a seadoo engine is that much harder on plugs than a car is that drives in all sorts of temps, rain snow, etc.
    I really appreciate your reply and will try to update this thread when I have more info.
