Kawasaki TS 750
Thread: Kawasaki TS 750
    I dream skis pacificmariner's Avatar
    Jun 2007
    oregon coast
    Kawasaki TS 750
    The engine in my TS died. I have a 750 dual carb with a slightly bent rod that I straightened using a piece of pipe. Wasn't too much trouble to fit. Needed a longer throttle cable and I used the 750 e-box. Having trouble with the spark arrestor due to available space. Out on the lake it has better response due to the bigger engine but now it takes 40 acres to turn it. Can't say it was worth the cost if I had to buy an engine but in my case it put this old boat back on the water.
    Apr 2019
    California
    Re: Kawasaki TS 750
    Try putting some sponsons on the back. I’m about to do it on my buddies ts with a 750. I had to get a angled spark arrestor adapter to get the spark arrestor to. Fit and it barley does
    Re: Kawasaki TS 750
    Been there, built that.....check out my thread, especially the part about the sponsons.
    --->http://www.pwctoday.com/showthread.php?t=393292
