750ss Xi Return Fuel Line — where to connect?!?
Results 1 to 10 of 15
    Aug 2018
    Texas
    I pulled my engine to perform the block offs and to replace the trim cable. Got it back together yet forgot where to connect the return fuel line. Where do I connect?
    Re: 750ss Xi Return Fuel Line — where to connect?!?
    It should go right in between the 2 carbs just under the choke shaft.
    Aug 2018
    Texas
    Ok, think I got it.
    Aug 2018
    Texas
    I have the engine re-installed and it cranks hard, but I can get it to fire up. Wondering if I misassembled something as it doesn't appear to be pulling fuel through the line. Maybe I thought I had the file line connected properly yet missed it. New spark plugs, and cleaned up everything else. Anything come to mind on why it won't get gas to flow through?
    Will it fire off if you shoot a bit of carb cleaner in the plug holes?
    Aug 2018
    Texas
    Yes. Didn't have starter fluid at home, so poured some 40:1 mix into the holes and replugged and it started up and died out quickly. Wouldn't restart after the initial burst.
    Aug 2018
    Texas
    Assume my next step is to replace the fuel lines and ensure nothing is clogged. Anything else you recommend.
    Aug 2018
    Texas
    Return line is clean and in good shape.
    I did a '95 Polaris yesterday that needed help down the carbs about 8 times before the fuel system was primed up and ready to go.
    Aug 2018
    Texas
    Thanks — I’m heading down that path as well. This ski has been sitting under a tarp for years. I’ve drained the gas, converted to premix, block-offs, etc.
