1992 Kawasaki 750sx Flatdeck
Results 1 to 10 of 12
    PWCToday Newbie nc_capozzoli's Avatar
    Jul 2019
    maui of the north
    picked up a basket case 750sx with a damaged hull.. figured since it needed fiberglass work, I might as do somethin' custom & deck it out.
    PWCToday Regular ROTZINGER's Avatar
    Jan 2011
    Cancun, Mexico
    Re: 1992 Kawasaki 750sx Flatdeck
    Quote Originally Posted by nc_capozzoli View Post
    Nice!
    I've always wondered how much structural integrity do you loose by flatdecking any ski? I mean you have to loose some, its a fact but has any of you guys snapped a hull in half in the surf?
    BR
    Enviado desde mi SM-G935F mediante Tapatalk
    87 kawasaki X2 with all the westcoast bolt on goodies
    88 Kawasaki 650SX
    01 yamaha XL700
    Jul 2019
    maui of the north
    not sure how much structural integrity is lost especially after it's all glassed over.. i cant imagine it would be too much loss.. there really wasn't much there.. thin hull walls, foam and storage tubes.
    nope, never snapped a hull in half.. that'd be gnarly though..
    Jul 2019
    maui of the north
    progress thus far.. wrapped the exhaust in titanium heat shield material my cousin had laying around, then bondo glassed the storage tubes in place, the one with the exhaust is borderline useless because it houses the exhuast pipe, the other tube I cut and screwed in a clear piece of plexiglass and added some goodies for anyone who takes a peek i masked off the transition piece with blue tape and filled her up with expanding foam. after the foam cured i trimmed and sanded to shape. then measured and cut the pads to fit the way they wanna.. gonna try the same mask-off and foam technique for the transition piece between the two pads before wrapping them with a new vinyl upholstery material.. 750deck-4.JPG750deck-5.JPG750deck-6.JPG750deck-7.JPG750deck-8.JPG750deck-9.JPG750deck-10.JPG
    PWCToday Guru kotarbi's Avatar
    Jan 2003
    san antonio tx
    You could build up the bottom layer with some glass and epoxy resin for more strength. I would recommend epoxy for glueing all that up. It’s strong as nails and will bond to smc
    Looking good
    07 HydroDoo
    Proforce 2.0
    06, 07 SXR's
    85,87,88 Wetbike’s
    Jul 2019
    maui of the north
    Quote Originally Posted by kotarbi View Post
    Looking good
    thanks, yeah plan to glass/epoxy over everything, and level the deck out at that point, the original tray sits nearly 1/2" lower than the side rails.
    Jul 2019
    maui of the north
    this ski came with a replacement gas cover, but no lock.. so I it'd be cooler and more retro looking if the gasser was exposed on the nose..so i drilled a 2.25" hole aligned with the original hole underneath. plan is to foam the void and glass the cover flush so it looks right
    Sep 2019
    Ontario, California
    that sticker will be a nice easter egg for anyone who doesnt know its there! nice ski
    Dec 2014
    SRQ FL
    Turn it into a fixed steer
    Jul 2019
    maui of the north
    Quote Originally Posted by StuRat View Post
    maybe in the future, but for now the wavejammer is my only fixxxy
    splatter paintjobs are tacky, and I hate them.
