Take a look! 650sx exh.
Results 1 to 10 of 12
    Jun 2012
    Owasso, Ok
    I placed an ad in the wtb for a dual input exhaust manifold. In the meanwhile after inspecting my current R&D mani. Are these for drilling and tapping?
    Post falls Idaho
    Re: Take a look! 650sx exh.
    Yep
    SE MI
    Yes Sir.
    21/64 drill and a 1/8" NPT pipe tap = dual cooling. Oh, and don't forget to do the pump too.
    Jun 2012
    Owasso, Ok
    Yeah, I’ve already got the stuff cause I just did the head. So I don’t have to buy anything ...well for that part anyway. I’ve read some run all three outlets in order to relieve pressure?
    2 in = 2 out.
    Plug the middle original single in.
    email watcon@watcon.com
    Please visit our web site
    Feb 2017
    Minnesota
    With the water going in right by the flange wouldn't the water flow straight into the motor, so there is no water flowing through the rest of the manifold to cool it?
    Jun 2012
    Owasso, Ok
    I have a dumb question what does the “b” mean when everyone talks about Factory Pipe?
    Also, I have a factory pipe for a 650sx that’s from the early 90’s. It is a little different than the ones I see now. It only has 2 screws and the outlet is in the middle not the bottom. Is it about the same? An old design?
    Any suggestions on should I sand and paint to make it look better?
    SE MI
    Quote Originally Posted by jetsteve2011 View Post
    I wouldn't do anything but install it and enjoy it!
    Jun 2012
    Owasso, Ok
    I already have a tach & dual temp gauge off of a scooter I was making “go fast”. It has fittings I could mount in the ocean pro head pictured earlier in the thread. Would there be any benefit to having a temp gauge on a “highly modified “ 650sx?
    Feb 2002
    Vancouver, BC Canada
    B pipe is the Yamaha version.
    Chester
    Stand up:
    98 SXi-Pro
    Couches:
    96 XP
    86 X2
