JS 550 Build. No experience building or riding.
Results 1 to 9 of 9
    Jul 2020
    Florida
    I always thought these were cool and figured it was a good pandemic project. I started this back in July but never posted anything.
    Lesson number 1. Get a ski with papers and VIN/HIN plates still on it. This one didn't have either of those.
    Jul 2020
    Florida
    Re: JS 550 Build. No experience building or riding.
    The fiberglass looks damaged in several places. I am told it is in a common spot which happens to be a weak point if your hitting a ton of waves.
    I dream skis 92Kawasaki750SS's Avatar
    Jul 2015
    St Louis, MO
    Looks like typical cracking areas. Welcome to the addiction. Good luck with the build.
    Sent from my SM-N960U using Tapatalk
    Jul 2020
    Florida
    Jul 2020
    Florida
    I got the carb off, used a wire brush to get all the black paint off. Maybe I will get it anodized or just leave it the silver metallic color it is
    Mar 2007
    Is Everything!
    Was the second HIN plate also missing under the battery tray?
    Jul 2020
    Florida
    It was missing from that spot as well
    Jul 2020
    Florida
    I got the electrical box off. A bolt was seized on one side of the cover. I drilled it out but kind of messed the hole up, not sure what to do about this yet.
    Also, anyone know of after market plug wires or even an entire after market electrical box? The plug wires were brittle and broke and several of the components in the e-box look pretty rough.
    Jet ski solutions rebuilds e-boxes. Get rid of that carb and save yourself a bunch of headaches and buy a good used or new mikuni SBN 44 carb! Those old carbs are nightmares!
    I know this is a old thread. How’s it coming so far?
