82 JS550 Carb Updrage and RPM Limiter Questions
    PWCToday Newbie WhatUpDude's Avatar
    Nov 2020
    So Cal, USA
    I've done some research and reading but I just want to confirm I am doing this right...
    I have an '82 Piston Port 550 that came with a round body 38mm carb. I acquired the ski with a disassembled engine so I don't know how it ran before. For what it's worth, I am doing a full rebuild on the motor and making some performance upgrades, however this will be a very mild pump gas 550.
    The ski came without a RPM limiter valve, but the wires are still in the electrical box. Rather then mess with the 38mm round body that came stock with the ski and figure out how modify the carb/fuel return line to make it run w/o the RPM limiter valve, I would like to upgrade to a 44mm SBN.
    If I do this, is it true that I can just tape off the wires in the box and call it a day? Or am I missing something?
    Any help would be greatly appreciated.
    Oct 2006
    under a ton of work
    Re: 82 JS550 Carb Updrage and RPM Limiter Questions
    yes,just disconnect the harness that went to the solenoid valve and you're done.
    Nov 2020
    So Cal, USA
    Quote Originally Posted by restosud View Post
    Thank you.
