650sx crank/case question
    Aug 2019
    BC
    Tearing into this motor, I don't think it's ever been apart. Some hitting in the cases where the bearings sit not sure if that much matters. The dowel pin that sits in the center case and the center ring on the crank is pretty sloppy as well if that's any concern? Also slight noise out of two of the bearings in the crank, the one I point to and the one on the coupler end is very slight. Into it this far I might just send it down for a rebuild as well.
    Re: 650sx crank/case question
    Any noise, you need to rebuild crank.
    email watcon@watcon.com
    Please visit our web site
    Aug 2019
    BC
    Yeah that's kinda what I figured. I'll be getting an order together with you too John, I'll need some stuff over the winter here
    Resident Guru sportsfreak29's Avatar
    Oct 2011
    Oakdale, Ca.
    Send it to Competitive Crankshafts’s in Idaho.
    '90 650sx, full mod with all the bells and whistles.
    '84 JS550/650 pump swap with PJS Viper engine.
    '93 550sx with a 650sx motor and Rhass pump kit.
    '81 JS440, full mod 550 PP motor. '
    '93 300sx/750 SP BOB.
    Special thanks to Chris Newmiller, the guys at Prowatercraft Racing, Rhaas Products, and Mitchell at M&M Marine!
