Cylinder Boring
Results 1 to 10 of 18
Thread: Cylinder Boring
    PWCToday Guru superhondaz50's Avatar
    Jul 2009
    Apple Valley
    Cylinder Boring
    Anyone have a reputable place that can bore a "blind" cylinder?
    I dream skis josh977's Avatar
    Feb 2008
    Cincy, OH
    Re: Cylinder Boring
    Messaged
    Sent from my VS988 using Tapatalk
    '04 SXR
    '96 SeaKaw HX
    Riverside, CA
    6
    Re: Cylinder Boring
    Q&E in Anaheim, CA have been around, seems like, forever.
    A couple blocks south of where Westcoast was.
    Bill M.
    Call and ask, about blind cylinders. I have not needed that kind of work
    before.
    Re: Cylinder Boring
    We do machine work here, southern WI. I have pistons kits, gaskets, and cn bore your cyl to match.
    John
    watcon@watcon.com
    email watcon@watcon.com
    Please visit our web site
    charlotte,nc
    Re: Cylinder Boring
    what do you mean by blind cylinder?
    96 superjet- rockered, -4, wide tray, adjustable footholds, kv148 mag setback pump, skat 7/14 impeller, rrp adjustable pole, blowsion ovp steering, 62t/62t, ada head, zeel A02T cdi, dual 44s, boysen power reeds, TNT SS chamber
    93-x2, newmiller ported SP750, milled head, R&D single 46 intake, sbn46, fpp blaster chamber pipe, hooker 9/15, umi, rhaas squirrel cage, dakine foot straps
    Jul 2009
    Apple Valley
    Re: Cylinder Boring
    It's an outboard cylinder, twin like a jetski, but the bores don't go all the way through. Each cylinder has little shelves on the bottom so it requires a different machine than a basic one some use to bore straight through.
    Jul 2009
    Apple Valley
    Re: Cylinder Boring
    Watcon, it's a Johnson twin with blind cylinders, can you do this?
    Re: Cylinder Boring
    Quote Originally Posted by superhondaz50 View Post
    Maybe. Call me at the shop during hours.
    Riverside, CA
    6
    Re: Cylinder Boring
    LA Sleeve is another old supplier that says they bore outboard engines.
    Bill M.
    Feb 2008
    Cincy, OH
    Re: Cylinder Boring
    The DT60 Suzuki outboard I had was a normal bore type setup. Is this an old azz outboard?
    '04 SXR
    '96 SeaKaw HX
