WTB Pro Tec Mach 2 pipe
Looking for a pro tec mach 2 specifically, not interested in the mach 1 version.
I have a speedwerx dry pipe that could be used for a possible trade.
Re: WTB Pro Tec Mach 2 pipe
Bump
Mach 2 is easiest to identify by the angle on the joint between header and chamber, has a lean to it not vertical like other pro-tec pipes. Looks like this:
I have one and I replied to you on your other want to buy.
Still looking.
Bump.
Just for fun, here's a completely unrelated picture of Starship.
The Mach 1 and the Coffman's are nearly identical. That Mach 2 looks VERY similar to the Wetjet pipes that are made by Westcoast.
I can kinda see how a Coffman Rocket pipe (I think that's what they were called) is sorta kinda similar to the earlier pro tec pipes, but I'd have to disagree on the wet jet I'm quite familiar with those and they're very different.
I do think the wet jet pipe is a great bang for the buck bargain though.
Originally Posted by
Storbeck
Yes, the 'Rocket' pipe. I just sold one early this year. Looks close, except the stinger pointed the wrong direction cause it was from a Raider.
Verses the Mach 1.......VERY similar. But different than the Mach 2 for sure.
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
