Cylinder Head Repair Options
Results 1 to 6 of 6
    Sep 2020
    Ohio
    Rebuilding a 99 GP 1200 npv, and the head is messed up pretty badly. From my understandings, my options for repair would be resurfacing and milling. Are there any other options, and what's the pro's and cons of each option? I will attach some pictures of the head. Thanks!
    PWCToday Regular CALJET's Avatar
    May 2008
    Ontario,Canada
    Re: Cylinder Head Repair Options
    A machine shop could mill the domes and resurface ---but I bet it would be cheaper just to find a good used cylinder head.
    A good used head would run about $100. Proper milling on that one will probably run about $100. Take your pic.
    Sep 2020
    Ohio
    Say I got it milled. It would increase compression right? Then I would maybe have to run higher octane, and would anything have to be done to the cylinders/pistons to compensate for the milling?
    Personally I wouldn't want to increase compression on one of these engines
    For starters, those heads are actually cast wrong right off the bat! The squish is reversed, actually trapping gasses out near the cylinder wall. A good machinist can recut those squish bands thus cleaning up the damage but ALSO lowering compression. THEN the whole head gets milled to bring that compression back up. 135psi works GREAT on those with 91 octane.
