650SC Fuel vent & return lines backwards
Results 1 to 6 of 6
    Oct 2020
    Chicago
    Took the SC out for its maiden voyage yesterday. Pull the throttle and it would go about 20 yards and die. Had to choke it to start back up. Seems like it was starving for fuel. Looking over things this morning and found the vent and return lines switched on the tank (previous owner never had it running, bought as a project). Before I drive back to the lake (in Illinois in November), does this sound like it would be the issue?
    Re: 650SC Fuel vent & return lines backwards
    Doubt it, vent and return should both just be open at the top of the tank. It would still function normally. Sounds like fuel starvation. Corroded or broken pickup tube. Pull the fuel pickup out of the tank and have a look.
    Oct 2020
    Chicago
    Tubes and filters looked good. I might swap the carb off my 650sx quick....142B0970-2875-4E87-8B5D-AB4F8594688D.jpeg
    Sounds like the filter in the carb may be stopped up to me
    Oct 2020
    Chicago
    Filter in the carb was clean. Popped it off and nothing in it. Carb off the 650sx is much smaller, so bailed on that plan...lol
    Quote Originally Posted by P-Money View Post
    You have to plug the filter ends, then submerse in a bucket of water, ten blow into them and watch for bubbles.
