I bought a 1994 Seadoo SPi. It was starting and running when I was testing it and afterwards every time I started it in the storage. Inside of th he engine compartment fuel smelled old, but I thought it wont be much of a problem since I was going to mix it with the high octane new fuel and use fuel enzyme. Took it to the lake today first time, started running it, but after about a minute it choked and since then I was not able to restart it. Checked for the spark, present and strong. Took of flame arrest and used carb cleaner, still no luck. Starting fluid, same result. I'm thinking old gas clogged the carburetor and now I need to rebuild it. So my questions are,
1. How could i check if it is a carb problem, before i rebuild it?
2. Is there any way to restore the fuel, if it is old?
3. I noticed there was no fuel filteron the line, should I put one in?
Thank you
Thank you
Comment
