New owner.. 94..slt 750. Basic questions
Results 1 to 10 of 14
    PWCToday Regular fijiblue's Avatar
    Dec 2014
    houston tx
    Hello all. I had a Yamaha long time ago and I just purchased this Polaris today. Please bare with me. I attached a picture of this valve looking thing. Not sure of iys purpose but obviously missing hoses. Can anyone tell me what it is and where do the hoses go?
    Also there are a couple old yellowish hoses that come from the under side of the rear of the ski. Close to the seat. Is it a vent? Or bilge pump? There is nothing connected to the hoses they are just hanging.
    And last question..the electrical box is just resting in the rear of the ski. Where does it properly mount?
    And how good is the oil system? Should I premix?
    Dec 2006
    Burnet, TX
    Re: New owner.. 94..slt 750. Basic questions
    The valve is a vacuum operated fuel shut off. They tended to cause problems and latter models did not come with them. I would remove it.
    Sent from my KING_KONG_3 using Tapatalk
    Dec 2014
    houston tx
    I appreciate it. I will remove it. Do you know about the other stuff I mentioned?
    Dec 2006
    Burnet, TX
    Vinyl hoses that have one end attached near the jet pump would be part of a bilge siphon that draws water out of the hull when water is moving through the jet pump. Each siphon hose should have two sections joined by a plastic elbow with a small hole in the side. The end that lays in the bottom of the hull originally had a metal screen. The elbow should be hung up well above the water line. If it is below the water line, water will enter the hull through the hoses whenever the engine is not running.
    Dec 2006
    Burnet, TX
    In my experience the oil injection is very reliable. I spent ten years as a mechanic at a Polaris dealership and never saw an engine fail due to an oil injection failure. However I recommend inspecting all the hoses. The only hard part I have seen fail on the oil injection is the check valves at carburetor end of the small lines from the pump. They should pop open at 1 psi. I have seen a couple that didn't close which allowed oil to drip into the engine when it was not running. This can cause excessive smoke shortly after startup and plug fouling.
    Dec 2014
    houston tx
    Sweet thank you! Should I do the tri fuel pump upgrade or leave stock?
    Dec 2006
    Burnet, TX
    I might consider upgrading the fuel pump, but in my experience that one is sufficient if the fuel line routing from the pump to the carbs has been updated. (Assuming the boat is stock.)
    Dec 2014
    houston tx
    Talking a bigger fuel line or what?
    Dec 2006
    Burnet, TX
    Originally I think the line from the fuel pump outlet connected to the rear carb and the other two were fed via hoses from it. Most that I seen have had it changed. The original connection at the carb was capped and the line from the pump outlet connected to a tee which then fed two other tees that were spliced into the short hoses that ran between the carburetors. I think this was done as a factory update. It would ensure even fuel feeding to all the carbs.
    Dec 2014
    houston tx
    I gotcha....I tested on it a little today..out of the water..just compression test. For 130 across the 3 cylinders...but I noticed a leak of gas from carb closes to the front of the hull....hard to see without pulling the fire screen off. But I saw 3 screws. So I assume some diagram or something is behind it..kinda looked like a triangle on the side of the carb.
    Is there a water outlet for the water pump? Like a outboard has. A pisser to ensure the water pump is working...forgive me im new to Polaris.
    Also I did get it started for a few seconds. But the sounded rough from the drive shift area. Vibration maybe the bearing is bad. I was told it had a new shaft but those are famous words haha. I did the shaft in my old jet ski years ago..so should be like riding a bike
