New owner.. 94..slt 750. Basic questions - Page 2
Results 11 to 14 of 14
    Dec 2006
    Burnet, TX
    Re: New owner.. 94..slt 750. Basic questions
    It's the diaphragm on one carb is leaking, you probably need to rebuild all three. Cooling water comes from the jet pump so the engine does not need a water pump. This machine does not have a pisser. Cooling water dumps out just above the jet pump.
    Sent from my KING_KONG_3 using Tapatalk
    Dec 2006
    Burnet, TX
    Drive line rattle is pretty normal when out of the water, especially if the splines have not been greased in a while. If you have major vibration or any kind of growling, grinding, scraping or squealing sounds I would pull the pump and inspect the entire drive line.
    PWCToday Regular fijiblue's Avatar
    Dec 2014
    houston tx
    I'm just going to redo the bearings in the drive line anyway. But I'll check everything out. I do wish it had a pisser tho. I'm always worried about overheating. And yes ill rebuild the carb. Its leaking pretty good.
    I know that I'll change all the oil lines and fuel lines but should I premix a small amount too? Or just trust the oil system
    Dec 2006
    Burnet, TX
    I have never run premix with oil injection except during engine break in.
