Hooking your bilge straight to the stator?
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    PWCToday Newbie Jeremy5501's Avatar
    Mar 2020
    Foslom
    Hey all,
    This may be a stupid question but I just got through mounting my bilge pump in my x2. Itís mounted with epoxy all the way towards the back of the hull. Because the stator positive and negative are so close to it it seems like it would look cleaner and be easier to mount it directly to the exterior bolts on the stator where the battery hooks up to. Is this the same as mounting it to the batter or will this not work? Thanks for the help
    Mar 2020
    Foslom
    Re: Hooking your bilge straight to the stator?
    Sorry not mounting it to but connecting it to the stator*
    Aug 2017
    North Dakota
    very interesting thought? I am in the middle of my build and would like to know this too!
    No because the stator produces AC voltage and the bilge pump is DC.
    Mar 2020
    Foslom
    Thanks for the info WFO! That explains why I got sparks when I hit the start button then lol
    Top Dog JC-SuperJet's Avatar
    Cypress, TX
    Will a Rectifier between the Stator and the Bilge make it work?
    I know, more components, more things that can go wrong.
    Simplest solution is to tie into Battery and include an inline Fuse.
    Sin City USA
    Are you sure you don't mean STARTER and not STATOR? The stator is on the front of the engine...inside the front cover...
    Quote Originally Posted by Jeremy5501 View Post
    I am not sure WTH you are doing here
    May 2005
    Right here
    Testing a fire extinguisher probably.
    Changes aren't permanent, but change is.
    Mar 2020
    Foslom
    Jonny thanks for the correction. I meant starter, not stator.
    Sorry for the confusion! Lol no fire extinguisher needed yet... but itís still early
