Pulled pump cone. Only water inside
Results 1 to 10 of 13
    PWCToday Newbie Crankshaft's Avatar
    Aug 2020
    Ontario
    Machine is a 01 gtx DI. I pulled the jet cone to change oil as part of end of season maintenance and just water came out no oil at all. Looks clean, no chunks of bearing etc.
    has anyone seen this? Maybe the last guy never changed oil, I bought this machine couple month ago and it drove perfect last time on the lake.Iíve got a new oring and the right oil, just not sure if this is something more serious like I need to rebuild the whole assembly?
    Re: Pulled pump cone. Only water inside
    At this point you need to reinstall the cone screw a fitting into the cone and do a leakdown test on the pump, it should hold 10 psi for 10 minutes, if not the fron seal or the rear o-ring are bad, you should replace the trear o-ring every time you take the cone off and the front seal as needed.
    And this is why it's recommended to change it yearly. It's not that the lube goes bad, you just need to know if it's OK.
    Aug 2020
    Ontario
    Okay thank you.
    Jun 2011
    I agree with the given advice for sure!
    A pinched o-ring when reinstalling the pump‘s oil cone will cause the leak down test to also fail and cause the oil to be washed out under the high water pressure produced from the jet pump.
    Be certain to do the leak down test after reinstalling everything.
    What would Chuck Norris do?
    Aug 2020
    Ontario
    Would you recommend just putting a bit of oil on the oring when reinstalling cone or should locktite be used like I’ve read? Seems strange puttting locktite on an o ring.
    PA
    There's whole family of sealing and thread locking products marketed under the name "LOCTITE". And the numbers change from country to country.
    If I remember correctly (and it's been a long while), the groove in the cone seemed kind of broad for the OEM o-ring. I might have used two o-rings side-by-side for insured sealing, but in any case, I wiped a small coating of RTV silicone sealer when it all went back together, for a little insurance. There is also o-ring grease available, and this has a slight swelling quality to it. Covers for life's imperfections. On the plug, don't use anything silicone or teflon tape, too slippery. You'll run the plug in too far and crack the cone. An old school paste sealer works best here, and BE GENTLE with the plug.
    Did you notice the color of the water that came out, clear or rusty? That was your only clue as to where you stand with things. Next spring, before rotating anything, remove the driveshaft guard and with spark plugs out, try and turn the coupler by hand, engine and driveline should turn smoothly.
    Aug 2020
    Ontario
    The water was clear, very clean looking so hadn’t been sitting in there long. The machine was being used few times Throughout the summer, apparently using water as a lubricant��
    I would fully disassemble, and inspect. On occasion I have seen there is enough oil coating the bearings tat they do not rust, and are fine.
    As said, leak down test upon assembly is very important. We see this all the time here, and typically it is a pinched o-ring on the rear cap. If you do this before you take the pump apart, you will know if the front seal is bad or not. If is is I would just rebuild the whole thing any way.
    email watcon@watcon.com
    Please visit our web site
    I always smear waterproof grease around the o'ring and front seal, never had issues.
