Pulled pump cone. Only water inside - Page 2
Results 11 to 13 of 13
    PA
    Re: Pulled pump cone. Only water inside
    Quote Originally Posted by Crankshaft View Post
    The water was clear, very clean looking so hadn’t been sitting in there long. The machine was being used few times Throughout the summer, apparently using water as a lubricant��
    If it was clear, this was a recent occurrence. You would not have gotten away with riding all summer with water in the bearings. Consider yourself lucky, so far.
    PWCToday Newbie Crankshaft's Avatar
    Aug 2020
    Ontario
    One other small issue now while I wait for the rebuild kit. This crack on the one ear, itís the nozzle side. Is this going to be okay, Iíd imagine a lot look like this after a while being plastic and all.
    It will be fine, somebody got carried away torqueing on it.
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. mackjust1
