650sx runs great in calm water boggy in choppy conditions
Results 1 to 10 of 11
    PWCToday Regular Camaro70's Avatar
    Jul 2020
    Long Island N.Y.
    Any thoughts on why this happens.I thought maybe the pump isnt loading in rough conditions,maybe wrong impeller pitch.I was reading about pop off on the carb.
    I have a brand sbn44 with the port match intake ,aftermarket pipe,Mariner head which Im pulling about 170 comp on it .
    It purs like a kitten in the driveway under no load and when washing out but very touchy when in the surf and chop.
    89 Kawasaki 650sx-Coffman pipe,west coast waterbox,WC exhaust manifold dual cooled,Mariner head,mikuni Sbn44mm,jetsport intake,k&n arrestor,blowsion 4 degree bars,r&d intake grate,OP ride plate,hydro turf
    83 550/650 WC pipe,supertrapp waterbox,mikuni bn44 WC ready carb,WC intake,WC head,jetinetics arrestor,blowsion 0 degree bars,odi lock one,Mariner ride plate,pjs intake grate,marble hydro turf
    86 550
    92 waverunner 650
    Sin City USA
    Re: 650sx runs great in calm water boggy in choppy conditions
    What are the jetting specs?
    Jul 2020
    Long Island N.Y.
    125 low
    150 high
    I think there may be an air leak From the base gasket.the compression was 160 left and 170 right cylinder.one of the spark plugs was dry after running it for a few minutes trying to dial it in
    86 550
    92 waverunner 650
    Sin City USA
    Sounds close what n/s and spring is in there?
    Jul 2020
    Long Island N.Y.
    The jets were the only thing I touched on the carb.I bought it brand new sbn44.the jetting was a little low 110/130 stock I believe it was.I didnt measure pop off.I was going to check the advance just to make sure that wasnt out of wack.Didnt want to mess with it to much I just dropped $200 plus on that and the bracket.wound up changing the throttle drum as well cause it didnt line up properly
    86 550
    92 waverunner 650
    Sin City USA
    Black or silver carb? From the original jets sounds like black.
    Jul 2020
    Long Island N.Y.
    Yes black.the silver model I think is just the regular sbn.Black was the high performance model that needs the primer but I could be wrong.Only did some minor research on it.Thought they were bolt on and go as opposed to Keihen with the external fuel pump.Wanted to eliminate all that
    86 550
    92 waverunner 650
    Sin City USA
    I have the correct specs for that. I am sure your pop off is wrong. The silver carb is actually closer to your jetting needs but still not spot on. When I get to my computer around noon I will post the correct specs.
    Sin City USA
    OK, so here are the different specs for the two carbs. Otherwise they are the same carb.
    Black SBN44 2.3NS, 65G, 100P, 125M
    Silver SBN44 2.5NS, 80G, 120P, 140M
    You need to change the jetting in the black carb to match the silver carb for your 650/pipe application. The only thing I would change beyond that is to a 150M
    Jul 2020
    Long Island N.Y.
    So 120/140 go with.thanks for the info
    86 550
    92 waverunner 650
