Piston pin size 750
Results 1 to 10 of 17
    Jul 2020
    AZ
    Piston pin size 750
    I recently purchased a js750 motor it seems to have very small piston pins I'm not sure what it means when everybody says small pin and big pin I have come across three different pin sizes in three different 750 if anybody else has had this problem I've ordered pistons for a small pin motor and the the Piston pins are still too big for the Piston pins I have for this motor the problem is I do not know what the motor is or what it came out of but the on the block it says js750
    Jul 2020
    AZ
    Re: Piston pin size 750
    One of the other motors cam from a ss sport
    there are only two piston pin sizes.
    20mm (small pin), or 22mm (Big pin)
    The engine in your picture is a small pin 750. If you ordered small pin pistons, and they do not fit, you got the wrong ones.
    One other possibility, someone has hacked together a crank, with smaller pin rods from another application.
    email watcon@watcon.com
    Please visit our web site
    Jul 2020
    AZ
    Jul 2020
    AZ
    I'm going to go get the correct tool to measure all three maybe somebody could help me out and thanks for the reply
    Jul 2020
    AZ
    The smallet one is what i need
    Jul 2020
    AZ
    Oct 2006
    under a ton of work
    smaller one on the right or in the middle?
    use a ruler to measure.
    Jul 2020
    AZ
    Looks like 18mm 20mm 22mm
    Sin City USA
    Frankencrank?
