Ring gap on a 2007 SC 1503
Results 1 to 9 of 9
    PWCToday Newbie gunner12's Avatar
    Apr 2019
    Washington
    Hi everyone, What is a good ring gap on my built 1503 seadoo engine? it will be studded with a 300 SC setup and 50lbs injectors.
    I did a search but didn't find anything. Thanks for the help.
    Apr 2019
    Washington
    Re: Ring gap on a 2007 SC 1503
    The gap now is 0.20 WSM spec sheet says .010-.018
    Mar 2010
    NC
    Did you mean 0.020" or 0.20"?? If 0.020" I would think that would be ok.
    Apr 2019
    Washington
    Quote Originally Posted by jeatmon View Post
    I'm using a standard Automotive feeler gauge and it says 0.20
    That is the biggest one I can fit in there
    Sent from my SM-N950U using Tapatalk
    Mar 2010
    NC
    OK, There is a lot of difference between .020" and .20" --- .20" is 1/5 of an inch or 200 thousandths of an inch.--- .020" is 20 thousandths of an inch.
    Maybe the gauge your looking at you can't see the decimal and it's really .020. In any regard, the gap should not be .20 but .020
    Apr 2019
    Washington
    Okay right on that makes sense. So I shouldn't need to go any bigger being that this will have more boost than a stock 215. I'll double-check with a better feeler gauge that actually has the right measurement.
    Apr 2019
    Washington
    So i put the decimal in the wrong spot! .020 is what i have currently.
    Mar 2010
    NC
    You are Good
    Apr 2019
    Washington
    Great!! thanks for the help!
