550sx Coupling Damper Install Direction
    May 2018
    CA
    - 1990 550sx
    - Solas 14/19 impeller
    - New pump bearings and seals
    Does anyone know why the coupling damper between the engine and driveshaft couplers needs to be installed with the cavity side forward? I have been having issues with the jet pump shaft threads stripping, causing the impeller to float around inside the pump case. I noticed the coupling damper was installed backwards during the most recent teardown. Before installing a replacement jet pump shaft, I'd like to understand why the threads are getting stripped. Everything else seems to be installed properly.
    Thanks!
    Idaho/California
    Re: 550sx Coupling Damper Install Direction
    On full circle 400/440s they had a bolt to hold the taper iron coupler on crank, so that cove was to make room for the bolt at the end of crank , never changed desighn
    May 2018
    CA
    Ok, thanks. I can probably rule out that being the cause to my thread stripping issue.
    Idaho/California
    10/4 ,is your mid shaft housing centered good , square with motor ? New impellor or used one ? Is that an aftermarket shaft ?
    May 2018
    CA
    I am going to reassemble everything and take a different approach than before. The impeller was new. Slightly chewed up leading edges now because of the thread issue.
    Although everything measures fine (straight edge across couplers and feeler gauge in coupler gap), I did not loosly tighten the shaft housing and align everything BEFORE torquing it down. I'll plan to get it all aligned, then torque when reinstalling. All clearances, measurements, and rotation seemed to be fine during the last installation, so I went ahead with it.
    Another interesting thing that may indicate a mis-alignment is that the section of the drive shaft inside the hull gets really hot when running it on a garden hose. The section outside the hull does not. I'm guessing it's mis-aligned in the shaft housing and rubbing causing it to get so hot.
    I came across a post somewhere at one point related to this topic, but can't seem to find it again.
    It does sound like you may have something in a bind.
    Idaho/California
    Those rubber damper get real hot , will steam up when water hits them when your riding , that's one reason to always have a splash guard in place
