550sx reed motor porting, where? - Page 5
Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
  1. #41
    charlotte,nc
    Re: 550sx reed motor porting, where?
    Quote Originally Posted by Lowflyin View Post
    I was going to go for a purple one for the looks honestly.. I figured it wouldn't be bad to tune in with the sbn(never tuned one) .. If the stocker works best though ill keep it on, what do you mean by 1 spring though ?
    Sent from my LM-V350 using Tapatalk
    it was meant to say one screen. not spring haha. a sbn44 is a good upgrade, i personally ran dual 38 sbns on mine. i wouldnt hesitate to send your reed engine to newmiller for some port work. but i would wait until the engine needs a rebuild or buy a cylinder that needs a cylinder bore and have the porting done at the same time.
  2. #42
    I dream skis E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    MCN said: "Same as when you had it... Just a new set of Wossners and a different cylinder head. As far as I know it is running with a single 44 SBN, Coffman half pipe and an SX pump."
    fastgtfairlane: What cylinder would you put on a '93 550sx? Or better yet, how would you max out the potential for a 550sx?
    Learning Slowly...
  3. #43
    PWCToday Regular Lowflyin's Avatar
    Sep 2012
    Monongahela
    I also hate to tear down a perfectly running engine too but the 1994 crank seals are always in my mind..
    ~'94 550sx
    ~'09 Yz450
    ~'04 400ex
    ~'46 J-3 Piper Cub
  4. #44
    charlotte,nc
    Quote Originally Posted by E350 View Post
    at the time i had a stock sx reed cylinder and had newmiller port it out. i had him do a freestyle port job. widened the exhaust ports, didnt raise exhaust port timing, and raised the transfers and cleaned up the intake ports. it had great bottom end for a 550 and a full pipe but had a wide power band. i had a pjs viper cylinder before that and it was very light switchy. honestly i think the sx cylinder has max potential with just some port work.
  5. #45
    charlotte,nc
    exactly why i said wait till it needs a rebuild or find another cylinder and cases to build a complete engine haha
  6. #46
    That’s just about the enough out of your sorry a$$ Annis.
    Too bad we can’t just tie ya up to a tree and let everyone you’ve scammed cast stones at your sorry a$$
    DO NOT make purchases from Annismayle143
    I feel like I missed something here
  7. #47
    Mar 2007
    Is Everything!
    Another one that needed to be added to your “ban this fool” thead Terry.
