Anyone mix oils in a jar for testing
Results 1 to 10 of 11
    Nov 2002
    CA
    Anyone try mixing oils in a jar to verify compatibility? We're always worried about oil clumping, so i figured im gonna find out if Pennzoil TCW3, and Seadoo XPS oils are compatible. I will mix and let it sit for a week or 2.... Has anyone else intentionally mixed other brands?
    Re: Anyone mix oils in a jar for testing
    You have a lot of time on your hands.
    I dream skis E350's Avatar
    Jul 2015
    Sacramento Delta, CA
    Please post up your results! Preferably with pictures.
    Learning Slowly...
    I think it's a myth. I don't even know what I run and mix together in my personal skis. Any parts machine get's 2 stroke oil strained into jugs and I use it. Been doing it for years,.....never had a problem.
    Nov 2002
    CA
    OK so after 3 days i dont see any clumping in the oils, i can still see the separation in color between them. In a couple weeks if i still dont see any clumping i will shake the jar to force it to mix, and ill come back with what i find
    May 2005
    Right here
    I'm not sure if I'd rather sit and watch the grass grow or sit and watch paint dry.
    Changes aren't permanent, but change is.
    Jul 2015
    Great!
    Learning Slowly...
    Mar 2007
    Is Everything!
    Like Myself I’ve never had a problem mixing oil, though I don’t practice it to that extreme Lol.
    This is interesting to me though, it’s cool you posted. Pretty certain you spent more time writing your first post than you have during your “experiment“ If not well shame on me...and you! ��
    I don’t think much is going to happen though aside from dye separation, both are Synthetic blends correct? Maybe a synthetic and conventional would yield different results but likely not by much based on synthetics being “blends” to begin with.
    Dec 2006
    Mesa AZ
    Its not a myth nor mystery. If you mix regular oil with castor bean based oil it will gel. Otherwise its fine. That's it.
    '94 Suuuperjet: 84mm 61x, ported, protec pipe, H2o designs waterbox, Newmiller head 190psi w/girdle, protec ride plate, Protec mod'd cdi, UMI grate, RN pole -4", rev footholds, solas prop, sweet green turf+wrap.
    Dec 2005
    Wisconsin
    5
    Been mixing oils for decades. After parting out about 300 sit downs, more than a few came to me with lots of oil in the injection tanks. I siphon/save/mix all of it. Burn a lot of it in my pump gas skis. What I can't burn myself I sell for $5/gallon. Never an issue.
    WHEN IN DOUBT, GAS IT!
