1998 SXI Pro porpoising
Results 1 to 10 of 14
    Aug 2020
    Edmonton
    Hey all. I just finished breaking in my rebuilt motor. Everything is great until you reach past half throttle. The ski instantly starts bouncing. Ive tried riding as far forward as possible while standing, leaning over the pole kneeling. Im 61 and 230 lbs and the ski just seems really unhappy with my weight anywhere. It appears to have Slightly cut down hull extensions And a long ride plate that was cut and then re-welded to full length. It appears the front also has flat sheets bonded to the sides ( maybe it had sponsons and they were removed). Any suggestions on how to tame the porpoising?
    thx,
    -Trent
    Sin City USA
    Re: 1998 SXI Pro porpoising
    Does the pump have the 2 wedge installed? Should be fat side up.
    Aug 2020
    Edmonton
    Yes, it has the wedge installed with the fat side up. I double checked it when assembling.
    -Trent
    Sin City USA
    Well you have all the anti-porpoising items on your ski, wedge, extended plate, hull extensions. Only other thing I can think of to help you would be 0 bars to put you further up in the tray. The rest will be tray time to get your riding position in best form. A full tank of gas helps a bit too.
    Aug 2020
    Edmonton
    In retrospect, I’m now questioning the wedge installation. I’ll have to check it tomorrow to verify. Thanks for the help.
    PWCToday Guru ImpactSportsTV's Avatar
    Jul 2003
    San Clemente, CA
    Also, you would be surprised what a difference a -2" length handlepole makes on those skis
    Aug 2020
    Edmonton
    I’ve been thinking about fabricating a shorter pole from aluminum.
    May 2005
    Right here
    Ride with the the bars ****ed just the tiniest bit as opposed to dead nuts centered. For some reason that always worked on mine and all I had was a Worx scoop grate and a Dominator extended ride plate.
    Changes aren't permanent, but change is.
    Aug 2020
    Edmonton
    Sin City USA
    You can also double up on the wedge, or try shimming the pump with a washer under the tabs on each of the rear bolts.
