DBP ported 6m6 cylinder R&D girdled head
Results 1 to 10 of 11
    Top Dog
    Dec 2007
    WI
    any one know about this cylinder or what this chamber is? 650 or 701. a 701 head gasget fits the head better than the 650
    Re: DBP ported 6m6 cylinder R&D girdled head
    Those cylinders run VERY well! Dallas Baker Products ("DBP"aka Pro-tec). What's the bore size and can you post a pic of the exhaust port?
    charlotte,nc
    if its over 81mm bore than its at least a 701. i think the 6m6 is 77mm bore stock. from what ive read, a 61x cylinder is just a big bore 6m6 cylinder
    Superjet I rode had that cylinder at 81mm, 650 cases,single 44 and protec pipe. 51mph
    Top Dog
    Dec 2007
    WI
    stock bore 650,thats a 701 gasket on top of 650 gasket just for reference there is a #3 engraved on top what does that mean?
    Top Dog
    Dec 2007
    WI
    porting
    I've seen tunneled out exhaust ports like that before.
    Sep 2002
    gold coast
    Its a 650 superjet chamber. they go ok, not has good as the 701 chambers
    Www.waxracingproducts.com
    PWCToday.com Is My Home Away From Home jdpilot's Avatar
    Sep 2006
    New Hampshire
    Quote Originally Posted by jrddillon View Post
    how much?
    Prospect Mountain Powersports
    Ltd 87 650SX- 43.6
    Ltd 93 X2- 45.1
    Ltd 87 hull/86 internals X2- 43.7
    92 WR3- 37.0
    93 WR3 w/Shuttlecraft JetSport
    94 WB1- Ltd
    09 superjet- stock 1 owner
    88 WetJet 432- stock 1 owner
    87 X2- stock 1 owner
    82 js440- stock 1 owner
    92 js440- stock 1 owner
    85 js550- stock 1 owner
    85 js440 super stock- Expert Womens Class
    85 js440- super stock- Region 8 Novice
    89 650sx- Ltd one owner
    Top Dog
    Dec 2007
    WI
    I have no idea what its worth
