Gtx di quit running 2003
    Jul 2020
    Paris illinois
    Was riding & started cutting out like a plugged fuel filter!! Replaced filter !! Removed pump from tank removed that filter also!! Rave valves work (as far as I know!! ) I removed covers & they moved freely! Local Dealer refuses to read computer??? Any ideas??!
    Jul 2020
    Paris illinois
    Re: Gtx di quit running 2003
    And I am at Kentucky lake!! Just hand tools!!GGGRRRRRRR
    PA
    Going out on a limb a bit with an 03, but.....
    The MPEM monitors many things, but not all things. You can use this to your advantage to do the "divide and conquer" routine. When you plug in your key to the post, do you hear the "everything's normal" beep sequence? Two short ones I believe. That and and the display should not show a MAINT flag. This will hopefully indicate there are no serious faults stored, and the problem may exist on the mechanical side, where the MPEM does not monitor.
    On a DI, you have to resolve yourself to testing stuff, or you'll go broke replacing parts on a hunch.
