88 650sx only wants to go after a jump/get air
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Aug 2008
    mpls mn
    Been trying to sort out a 88 650 I got that didn't want to go, always felt like it was only half throttle
    Then sometimes it goes fine
    Lately I've been able to reliably repeat this if it's running slow but I get the pump out of the water for a sec off a wake etc then it spins up and the ski will rip until i get sick of proposing and let off again
    Also it's taking on water, haven't found any leaks yet, anyone ever have problems with a electric bilge taking on water through the hull fitting ? Thought about adding a check valve or loop
    Sin City USA
    Re: 88 650sx only wants to go after a jump/get air
    pop off is set wrong
    Aug 2008
    mpls mn
    ive found confilcting info on what the pop off should be, i rebuilt the stock carb and tested pop off around 32psi, used a sbt rebuilt kit which im now told is not good? this ski ran good for a trip or two after the rebuild.
    Jul 2020
    CT
    I have basically the same issue ... and while I'm NO expert on these things I truly believe it to be crank seals. I had the same issue back in the mid-90s and now again it happened last weekend to my 87.
    Blow out the cooling lines, check the exhaust hoses and make sure the carb is tuned first, of course
    PWCToday Regular N.Penley's Avatar
    Aug 2017
    Boone Lake, TN
    I had a 550 that ran the exact same way after a SBT motor swap. I never got it sorted out and sold it. This was my only experience with SBT.
    Sin City USA
    What carb? Stock or A/M flame arrestor? I am still betting on pop off too high
    Aug 2008
    mpls mn
    stock carb, stock intake, westcoast pipe. the ski had the carb rebuilt when i got it, and the pop off was set way low like opened at 1-2psi
    i put a new spring it and set it at 19psi
    then i rebuilt the carb and its opening about 32psi
    it worked randomly or for the first few minutes on water at 19 and 32
    Aug 2008
    mpls mn
    is there a way to test the external fuel pump? what jets should i be using?
    Sin City USA
    The difference between 19 and 32psi pop off is day and night difference. When you rebuilt the carb did you use the spring in the kit or reuse the old one?
    Aug 2008
    mpls mn
    i used the spring in the kit.
    i got the ski with a spring that had almost no hold back pressure, 1-2psi. i replaced it with a spring from the hard ware store cut down then it was at 19 pop off. rebuilt using spring in kit now pop off is around 32
